1 - 3 of 3 Posts
Hey guys,
Currently have some issues with my tune. Turbo D16 With Dry nitrous on Aux output. I find repeatability always in 4 gear around 5800 RPM my car will hit some type of protection however i have no idea what?
Could someone review the tune as well as datalogs and tell me if they can see anything?
Thanks all the best
Problems occur at
Log 1 is 6:17
Log 2 is 1:28
Map and files located here
Please help review Datalog - nuisance engine cut? - Hondata
Note necessarily the same since you are using Hondata - I am using *.bin files. But I have had a situation where the car at a very specific RPM would hit some type of "protection". It was strange, when under no load (in neutral) it would rev right out, but when under load it would encounter what seemed like a rev limiter, but well below where the limiter had been set.
I created a new file and copied the map data into, and never had an ounce more trouble. Of course this was after I tried all different types of ignition and fuel related repairs but it turned out to be the tune data that was corrupt.
Something to try anyway. Good luck!
1 - 3 of 3 Posts
