1 - 14 of 14 Posts
W
Ok, I think I have a vacuum leak somewhere. And I believe I have narrowed it down. Can someone please pop thier hood and talk a look at thier evap selenoid. It looks like this and is located on the back of the intake manifold...
WITH THE CAR RUNNING. Pull off the round black top. It should slide right off. It will then look like this.
Put your finger over the top of that black stem. Where you just pulled the round thing off. Do you feel any kind suction????? I do and I think this is where i'm getting my vacuum leak causing my high idle. I can plug the hole with my finger and my idle will go down. Let me know if you guys feel any kind of suction at idle?? I think my evap is broken.
W
If anyone can help it would be much appreciated!
W
Thanks man! I really appreciate it.Let me know what happens when you pop your hood...
W
Bump, everyone's got this on thier car and nobody can't help me?
The evap solenoid opens once the engine reaches operating temp. Sounds like your cap is broken.
W
If it opens when it reaches operating temp. then mine would working. Or mine could be broken and be staying open all the time???
W
X292J said:
ill help u out! i have to check my shizel tomoorow so ill check that out 2 for ya
Let me know what you find. Maybe you can try feeling for suction on cold start-up and when it's also running warm? I just don't want to spend money and replace something that's not broken...
Del sol
well i checked and mine had no vacume, even when i reved, nor did it blow air this was when the car was @ operating temp. havent tried cold yet
i used the spit bubble technique btw
W
Thanks man. I guess this confims that I need a new one. Could be why I failed emissions... Thanks again! :smile:
I managed to pass emissions without the evap solenoid... my JDM ecu has no funstion for the solenoid, and has no barometric pressure sensor =) Maybe thats why I barely passed under the line for CA smog.
1 - 14 of 14 Posts
