1 - 2 of 2 Posts
D
I just got a code 11 on my 93 d16z6 and it says that a code 11 is idle mixture adjuster sensor malfunction or circuit fault. Question is where is the idle mixture adjuster sensor?I know that it is not the iac, or tps, or the map sensor cause they all have seperate codes. I'm assuming that it is on the throttle body but not exactly sure. Please help.Thanks.
1 - 2 of 2 Posts
