1 - 9 of 9 Posts
I have a D16 SOHC Non-VTec with bolt on turbo
Here are the details:
-IHI Turbo which is about the size of TD04 or smaller,
14g I think...(just quessing)
-Engine head ported and valves grinded
-Metal Head Gasket which is abt 2mm thicker than
stock gasket in order to have a lower compression
-Engine Block rebuild/overhaul with Stage-1 oversize
stock pistons due to blown engine(I had a poor tuner
before)
-Injectors from Honda Prelude H22A VTec engine
which I'm not sure if it's enough for my engine, if not
please advise me...
-Walboro 500cc fuel pump
-FSE fuel regulator
-HKS SSQV BOV
-GReddy E-Manage engine management
-2.5" downpipe and 2.5" exhaust piping all the way to
end
Question is, how much boost can I pump in with this setups? Currently running at 0.5bar and not very satisfied. I was thinking about pushing it to 0.8bar or 1bar and is it possible with stock pistons? Do I need bigger cc injectors than my current ones? By the way, do I need to remove the stock fuel regulator which is connected to the fuel rail since I already have the FSE fuel regulator fitted?? Pls get back to me asap...thankz alot guys!
Lurking... ಠ_ಠ In Your Thread
DOUBLE-POSTING IS BAD JU-JU. YOU ONLY NEED 1 THREAD. JUST BECAUSE IT FALLS IN DIFFERENT CATEGORIES DOESNT MEAN YOU CAN POST IT IN 2 OR 3 DIFFERENT SECTIONS OF THE FORUM.
This will be deleted soon
i think this MOFO is a bot....
IDK about H22 injectors.
I'm thinking you'll need bigger ones. OEM parts are good for around 220whp with a good tune.
Check out www.turboD16.com you may get help over there.
I've seen your other post, so I won't harass you.
1 - 9 of 9 Posts
