What is the minimum amount of piston to head clearance that I can run without my engine blowing to crap....I have done some reading and some say somewhere around .040"..at the moment I have about .150" ish w/ headgasket..what do I figure in for rod stretch? I am asking this because I have put vitara pistons in my d15b vtec and was planning on running a thinner .020" headgasket to give it a mild boost in compression...also has anyone had valve to piston clearance issues?
Well?
i assume your a turbo motor,no need to worry about rod stretch that much unless you are revvin like a mofo and have super tight clearances. Are you using a stock cam? if your only using a thinner gasket, your fine, but i wouldnt reccomend it with a turbo motor.
yea its going to be turbo...and I'm using a skunk2 stg 1 but I plan on claying it with locked vtec lobes just to be sure...why wouldn't you reccommend the thinner hg with turbo? more prone to blowing? its a mr gasket mls.. i used a comp calculator and it brought me to about 8.5:1...I need a little power w/o the turbo because I plan on running it n/a until I can get all my parts together...
Well?
yes, more prone to blowing, just shave the head instead. safer that way. and with the D15B its gonna be 8.5:1 without anything being shaved or thinned so your fine, atleast according ot the Zeal
cool I'd like to have decent power at cruising and low speeds and not just when I'm in full boost...this engine will be seeing some n/a time until i can finish my turbo setup and hopefully still have enough to spend on the extra gas it'll be burning....probably run a slightly thicker headgasket and just get the head milled
