1 - 14 of 14 Posts
allwheeldriveturboboxer
'08 Mazdaspeed3
Hi
Maybe it will sound stupid but i have to ask.
If i put vitara pistons wich rings do i put honda or vitara
i'd say either/or. i like OE honda rings. i believe the vitaras usually come with hastings, which are fine. i imagine the grooves and dimensions of the rings and their lands are identical, someone know for sure?
racist-bigot-sexist-homophob
They come with hastings rings. But for future reference: whatever piston you use determines the ring set you use.
The ring thickness is different depending on the piston (found this out the hard way).
1999 civic Hatchback
Well i used Honda spec rings(Hastings) in my build and i sell them with Honda sepc rings..Except for the 75.5mm pistons that i sell them with Suzuki spec rings cause my supplier dont have Honda .020 rings.
So you can use either Honda rings or Suzuki rings.
If you need them let me know.
if you use the vitara pistons on a honda block use the honda piston rings. i believe thats how fjt supplies them
I sure hope he doesn't supply them this way. The rings should be matched to the piston. The block they're going in doesn't matter.
For more info reference:
http://www.hastingsmfg.com/Catalog/master.asp
Hastings master catalog gives individual top, bottom, and oil control ring thickness for many different makes, models, and engines.
Triple posts suck
94 civic si
triple post ftl!
lol..somethings wrong with the board.. i tried to post several times and it didnt let me...no i find 2-3 post.. sory about that
1 - 14 of 14 Posts
