D
can i run 11 compression Z6 pistons with d15 rods on a Z6 block...and run turbo at the same time??
Nope!...
YES!!!!!!!!!!!
Only if the rods are D15B and psi kept to 5 psi intercooled...........
VAFC tuning......no way!
O
I think he is refering to a USD D15 not the JDM. but who knows.
Basically, if you have a JDM D15 it's the same as out D15 except smaller pistons diamater only. rods and all else is the same. (jdm d15 v-tec that is)
if you have a USD D15, then the rods are shorter so no you cannot run Z6 or D16 rods.
Thanks Oscar that is what I was refering too.
D
wat i mean is can i run usdm d15 rods in a d16z6 block...i would need to put the d15 crankshaft...all this would do in theory is lower my compression...so i can put d16z6 11 compression pistons and hopefully run turbo :cockbloc:
O
no the cranks journels are I believe also smaller on the D15.
