well my new setup to just get me around now, because recently Ive just had bad luck. my setup for the time being is d16a6 929 rr itb's aem cam gear 4-1 header with a 2 1/2 collector (non ebay). 75 shot dry for when I need it. this is all in a 1990 crx si. but the motor im building on the side. is a d15b7/z6 mini, vx rods pm7 pistons. heads redecked ,3 angle valve job ported and polished. 4-1 header , 929rr itb's, jge stage 3 na cam cam gear. and a shot. I will get pic's of my progess here soon. shout out to slo sohc for help..:TU:
I will get more pics l8ter
pictures could be a bit brighter. but the setup looks solid. any reason you chose to put your AIT sensor on runner #2?
cell phone pictures suck. sorry. the reason the AIT sensor is on the #2 runner is beacue the manifold is a dupfi mani( no injecotor holes) . but when i can my digi camera ill take better pics when they are on the a6.
Those very long coupler hoses look a bit nasty, is their interior smooth and inside diameter constant? Those are very important things, if there's ridges or jumps in diameter it won't probably work very well..
Because they're very long and a lot thicker than your manifold. How you've arranged the step to inside, to properly fit into manifold? Please don't say you've just cut your manifold, and then put straight hose on them.. even there's grinded taper or something into runners, it would still make lots of turbulence I think.
