1 - 20 of 28 Posts
Discussion Starter · #2 ·
Test failed :(
I can see them
Discussion Starter · #4 ·
I can see them
Yes, but it is the same picture. It was meant to be two different pictures. I am trying to make a post with pictures in it. I am on an iPad. When I click on the picture icon, it only allows me to insert from a url. I can't do that because my post count isn't high enough. There is not option to upload from my device from the "insert picture" icon. I can upload from my device to the attachments, but it will only do one picture to a post no matter if I upload several and attach them separately. It changes all pictures to the last one I uploaded.
I tried setting up an album just now. I will see if that works.
98 Civic HX D16Y5
But they're tiny
click em they get huge. op, if you can find a way to "right click" and find the properties of the image, copy and paste the address url. post that with a space somewhere and Ill edit it to work for you.
Discussion Starter · #7 ·
I'll give it a try.
Text Blue Web page Line Computer icon
see what Im referring to?
even though its shitty, it should hopefully give you an idea. or you could to the hosting site part.
Discussion Starter · #11 ·
I knew that but it didn't work the first time. It does now.
Kev, if all else fails. There's a bunch of sites that require no account to upload and post images from.
Such as:
I have tons of sites with images, but this tech board doesn't allow me to post links with a low post count. Thanks for the help, though!
Edit: It wouldn't accept my reply just now because I quoted your link! I had to delete it from your quote. Hilarious!
Discussion Starter · #12 ·
I do understand, slo. However, there is no "right click" on an iPad. I will just wait til tomorrow and use my desktop at work to ask. I appreciate the help!
Reactions: slo_eg8
98 Civic HX D16Y5
Such as:
Haha sorry I forget about the post count limits.
Nice! That's a little ridiculous.
sorry for the inconvenience. you might get lucky with it to allow you to post, but if not, like I said, just leave a space somewhere and Ill edit it to work for you.
98 Civic HX D16Y5
The fuck happened there??? I should be able to quote you
Ediy: apparently there was only one /quote in brackets.
Discussion Starter · #16 ·
I tried slo. It wouldn't allow me to post a link no matter how many spaces I put in it. I couldn't trick it.
weird, others have been able to. will it let you pm it to me? maybe I can still help you out.
Discussion Starter · #18 ·
this
Alloy wheel Rim Tire Wheel Spoke
like this Alloy wheel Rim Tire Wheel Spoke
not this Alloy wheel Rim Wheel Tire Spoke
definitely not this
Alloy wheel Tire Rim Automotive tire Wheel
Discussion Starter · #20 ·
Could it be the image posting limitations set on noobs for links and images???
I don't see an image barrier for noobs. The link barrier is annoying, and that is because of my post count. I read through the forums, but I am not wise enough in the ways of the d series yet to help, so my post count will stay like it is until I can manage to get some good advice in. No worries. I will figure it out. The post above with the 4 images did exactly what I wanted it to. I just had to wait until I got to work today to make it work. I couldn't get it sorted from my Ipad at home.
1 - 20 of 28 Posts
