1 - 20 of 47 Posts
formerly Kit88
pics of my fried vitara pistons
Piston # 4
Piston # 3
Piston 1 and 2 are ok.
Any idea what could cause detonation, I know that "lean" was the key, but what causes lean conditions??
not enough fuel to cool combustion, too much ignition timing
lean conditions are caused by not enough fuel being injected...
racist-bigot-sexist-homophob
Wow that sucks.
detonation is a pressure induced event - the rising piston increased pressure which also increased heat to the flash point of the gas/air mix
pre-ignition is a heat induced event - an imperfection on the piston was glowing red hot which ignited your mix
both will melt/destroy pistons
who tuned your car?
can you post up your uberdata fuel/timing maps?
formerly Kit88
who tuned your car?
Car was tuned for a friend in Mcallen, car was runnign fine for 6 months, was tuned on Uberdata.
Pistons are vitara 75mm on my d16z6 block with eagle rods.
First time ever seeing vitaras fried. What was your fuel setup?
formerly Kit88
Do you have a WB gauge in the car to monitor AFR's?
formerly Kit88
Nope at this time, I have and AEM wide band but the gause is from another brand I´ll try to hook it up asap.
I´m an idiot cause on dyno last week a/f was at 14.6 but I thougth that sniffer was reading bad.
Do you have a boost gauge in the car?
Yeah 14.6 is...:shocked:
formerly Kit88
Yes, I have boost gauge, oil pressure gauge and egt gauge but disconnected!!
erw yeah 14.6 is fine for cruising at high speed low throttle = low load
but under a full load you need to be down in the 12's
welp, time to build it bigger and better!
1 - 20 of 47 Posts
