1 - 20 of 26 Posts
first up, pics...
WTF is up with this flange? will i be able to use this one?
on to the story, i found these on craigslist... picked them up for $40, no shaft play at all
these are internally wastegated turbos right? do i need to bypass that waste gate? if not what is it set at?
what kind of power are these capable of on a D16z6?
these are also oil cooled correct?
one more question, what size charge piping should i use with one of these turbos?
thanks in advance, Derek...
with one of those you dont need ibeams and vitaras. you would max one of those things out before you would need a built motor.
ok... so its good for a stock motor build, thats fine...
I however will be building my motor so i wont use it, ive got a buddy wanting to do a stock motor build so one will be perfect for him
insert user title here
domestic.
talk about instant spool. power would run out very soon though.
id personally resell them and get something a bit bigger.
or do a twin turbo setup ;)
how hard would it be to do a twin turbo setup with something like this tho? and still be able to keep PS/AC?
domestic.
LOL,
that would be some serious fabrications skills. maybe with one.
look for a greddy kit. people are always trying to up size from those, and theyre ac compatible i believe
1.8 nawz powa
a twin turbo wouldnt be a nightmare, just some custom fab work, but with the ps and ac...they might be hard due to no room.
domestic.
whitey from HMT did a tt setup years ago that turned out pretty nice.
Abaz did one too but neither where ps/ac compatible
Discussion Starter #19
Ummm, you can give them to me. J/k (somewhat)
Use one, I wouldn't build a motor for one, you may get into the low 200s w/ one.
hrmmm... ill give you the funky flange one and a good batt to play with for a decent sized turbo for a midly built D16z6? ;)
1 - 20 of 26 Posts
