1 - 2 of 2 Posts
J
the first problem i had was my car was knocking...then i changed the rod bearings and it stopped for like 20 seconds...then i added a oil pressure gauge and now the car wont start...help is greatly needed...
W
knocking i would think would be caused by.....timing or inaccurate a/f ratio.lean mixture. i think you need to check that out because that is what sounds messed up. you say you put an oil gauge and now it doesn't work well....can you kinda identify the problem like you check the fuel and stuff....actually now that i think about change your spark plugs.
1 - 2 of 2 Posts
