1 - 1 of 1 Posts
All stages come as a complete kit including disc, pressure plate,
throwout bearing, pilot bearing (when applicable), and alignment tool.
Assembled in the USA
FX400: Race Performance Clutch Kit
The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
FX400 Clutch Kit
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
88~88 - 1.5L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
88~88 - 1.5L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Four-puck ceramic Dampened disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Six-puck Rigid ceramic disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Four-puck ceramic Dampened disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Six-puck ceramic Dampened disc
01~05 - 1.7L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
01~05 - 1.7L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Four-puck ceramic Dampened disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Six-puck ceramic Dampened disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Four-puck ceramic Dampened disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Six-puck ceramic Dampened disc
06~08 - 1.8L 4Cyl - HD Plate - Four-puck ceramic Dampened disc
06~08 - 1.8L 4Cyl - HD Plate - Six-puck Rigid ceramic disc
FX400 Clutch/Flywheel Kit
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Four-puck ceramic Dampened disc - ALUM flywheel incl
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Six-puck Rigid ceramic disc - ALUM flywheel incl
00~11 - Transplant - K/Motor-F/Trans 4Cyl - HD Plate - Four-puck ceramic Dampened disc - ALUM flywheel incl
00~11 - Transplant - K/Motor-F/Trans 4Cyl - HD Plate - Six-puck Rigid ceramic disc - ALUM flywheel incl
FX500: Race Only Clutch Kit
The versatile FX500 System uses either the Power Plus I or Power Plus II Pressure Plate along with a solid center 4 or 6 wing (paddle) Ceramic Button disc. It is designed for maximum holding capacity with no compromises.
***Warning: The FX500 is a Solid Hub (rigid) disc that engages and disengages instantly. This is a Race Only clutch.
FX500 Clutch Kit
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
88~88 - 1.5L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Four-puck Rigid ceramic disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Four-puck Rigid ceramic disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Six-puck Rigid ceramic disc
00~11 - Transplant - K/Motor-F/Trans 4Cyl - HD Plate - Four-puck Rigid ceramic disc - ALUM flywheel incl
01~05 - 1.7L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Four-puck Rigid ceramic disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Six-puck Rigid ceramic disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Four-puck Rigid ceramic disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Six-puck Rigid ceramic disc
06~08 - 1.8L 4Cyl - HD Plate - Four-puck Rigid ceramic disc
FX500 Clutch/Flywheel Kit
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Four-puck Rigid ceramic disc - ALUM flywheel incl
Lightweight Flywheels
Reduced mass equals increased acceleration. Reduces turbo “lag” in turbo-charged engines. Increased supercharger efficiency due to less drag on the crank. Improved mid-range torque in normally aspirated engines. Two-piece unit featuring a high carbon steel replaceable friction surface. SFI Certified. Rev Quick - Typically 50% Lighter and Stronger than OEM
88~88 - 1.5L 4Cyl - ALUM - lbs
90~91 - 1.5L / 1.6L 4Cyl - ALUM - 9lbs
90~91 - 1.5L / 1.6L 4Cyl - STEEL - 11lbs
92~01 - 1.5L / 1.6L SOHC 4Cyl - ALUM - 9lbs
92~01 - 1.5L / 1.6L SOHC 4Cyl - STEEL - 11lbs
99~01 - Si - 1.6L DOHC 4Cyl - ALUM - 9lbs
99~01 - Si - 1.6L DOHC 4Cyl - STEEL - 11lbs
01~05 - 1.7L 4Cyl - ALUM - 9lbs
01~05 - 1.7L 4Cyl - STEEL - 11lbs
02~10 - 2.0L 5 Speed 4Cyl - ALUM - 10lbs
02~10 - 2.0L 5 Speed 4Cyl - STEEL - 12lbs
02~10 - Si - 2.0L 6-Speed 4Cyl - ALUM - 10lbs
02~10 - Si - 2.0L 6-Speed 4Cyl - STEEL - 12lbs
06~08 - 1.8L 4Cyl - ALUM - 10lbs
GO TO NOPI/CLUTCH MASTERS Catalog for model specific web prices and details
Contact the salesmen below or PM me for our best deal on CLUTCH MASTERS Clutch & Flywheel kits
1 - 1 of 1 Posts
