1 - 3 of 3 Posts
All stages come as a complete kit including disc, pressure plate,
throwout bearing, pilot bearing (when applicable), and alignment tool.
Assembled in the USA
FX100: Street Performance Clutch Kit
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
FX100 Clutch Kit
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
88~88 - 1.5L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Dampened hub steel-backed organic lined disc
01~05 - 1.7L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Dampened hub steel-backed organic lined disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Dampened hub steel-backed organic lined disc
06~08 - 1.8L 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc
FX100 Clutch/Flywheel Kit
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc - ALUM flywheel incl
00~11 - Transplant - K/Motor-F/Trans 4Cyl - HD Plate - Dampened hub steel-backed organic lined disc - ALUM flywheel incl
FX200: Street Longevity Performance Clutch Kit
The FX200 System uses the Power Plus I Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque holding capacity to the FX100, however, its life expectancy is increased 2-3 times with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer.
FX200 Clutch Kit
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
88~88 - 1.5L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Dampened hub full-face Kevlar lined disc
01~05 - 1.7L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Dampened hub full-face Kevlar lined disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Dampened hub full-face Kevlar lined disc
06~08 - 1.8L 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc
FX200 Clutch/Flywheel Kit
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Dampened hub full-face Kevlar lined disc - ALUM flywheel incl
FX300: Street/Race Performance Clutch Kit
The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement.
FX300 Clutch Kit
84~87 - 1.3L EV1 1.5L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
88~88 - 1.5L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
89~89 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
90~91 - 1.5L / 1.6L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
92~01 - 1.5L / 1.6L SOHC 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
99~01 - Si - 1.6L DOHC 4Cyl - High rev pressure plate - Dampened hub segmented Kevlar disc
01~05 - 1.7L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
02~10 - 2.0L 5 Speed 4Cyl - High rev pressure plate - Dampened hub segmented Kevlar disc
02~10 - Si - 2.0L 6-Speed 4Cyl - High rev pressure plate - Dampened hub segmented Kevlar disc
06~08 - 1.8L 4Cyl - HD Plate - Dampened hub segmented Kevlar disc
FX300 Clutch/Flywheel Kit
85~99 - Transplant - H/Motor-B/Trans 4Cyl - HD Plate - Dampened hub segmented Kevlar disc - ALUM flywheel incl
00~11 - Transplant - K/Motor-F/Trans 4Cyl - HD Plate - Dampened hub segmented Kevlar disc - ALUM flywheel incl
GO TO NOPI/CLUTCH MASTERS Catalog for model specific web prices and details
Contact the salesmen below or PM me for our best deal on CLUTCH MASTERS Clutch & Flywheel kits
91 CRX Si
I didn't even know Nopi was still around! Sweet!
1 - 3 of 3 Posts
