1 - 12 of 12 Posts
V
hello i know that d16 on boost
with pcv valve is fuck up and can get you blow up
rings
can i just cut the pipe that go to intake mani?
V
If I just took the hose off the intake manifold
and block up the hole on the manifold and the hole of the pipe that it leaves it will be ok ?
E
^^ hows your engine bay look?
I'm doing the pre-turbo cut.. inside of an open system.
V
see the pic
not mine but look like this engine bay !
the MAD scientist
mines a bit different. The FPR has kept its own stock line. I put a T where the PCV was connected to the IM and used that as a signal line for the BOV and boost gauge. I'll try and get you pics later to show you what I mean.
i just unplugged the pcv hose that went into the intake and let it dangle...I used the port in the manifold left by it for the wastegate and the BOV
1 - 12 of 12 Posts
