I have two eg hatchbacks one is a 95 dx with a jdm d15b vtec i think it has a ex harness in it but its not in the best shape and a 92 dx with d15b7. I am planning to swap the motors out with each other. i was looking at the plug on the shock tower bc i am going to use the engine harness thats with the d15b7 in the 95 and vice versa.I noticed a couple differences the location of the D11=throttle position sensor(pink/black) wire on my 92 is a mint green? I am also missing : D21=sensor ground 1(green/blue) D17=MAP sensor(pink/white) D19=sensor voltage for MAP(yellow/green)
The map sensor is mounted on my firewall in the 92 so the missing wires on the shock tower plug sorda make sense.
Im just not sure on what i will have to do to make everything work flawlessly. I know I can repin the plugs. Has anyone done this before maybe a guide or write up on it??
