1 - 4 of 4 Posts
well this is what i plan to do and i wonted to see if anyone had a better idea!!!
d15 block
a6 head
milled
port and polish
oversized valves
stage 2 cam
adj cam gear
springs and retainers
jrsc 5lb or 10lb (found one cheap, not changing)
fuel pump
injectors
and new custom exhaust
i plan on stocking up on all the parts by may next year and building it in april or so
if you would do something differently let me know, i have time and i wont to do it the best way possible
what are you doin for tuning?
& no need to fix the head up with all of that stuff...if your only going to run 5-10lbs on a stock bottom end...
I would take the money invested in the head & put some thick rods in a d16 bottom-end....
then you could run more boost....
& be cheaper & faster....
well i figured i will a a point but for now with money as tight as it is, ill biuld the top end and boost it then next year build the bottom end
i think you might have that backwards a bit. you'd wanna do up the head so that you can get the most hp out of that 5-10lbs of boost, since you cant really get much more out of a honda supercharger. and if he's sticking with the sc, the bottom end will pretty much handle whatever he throws at it..... unless he decides to throw a turbo on there one day.
1 - 4 of 4 Posts
