1 - 7 of 7 Posts
89 EF 4wd sedan
Hi guys,
I'm pretty stocked how this build is coming along and wanted to post some pics. Just finished getting it hydro blasted with a glass aggregate and it came up minty, almost polished looking...
Anyway i had a quick question about the connecting pipe between the water pump and the thermostat housing #9 in the below pic
(19505-PM7-E00) I pulled mine off and its quite heavily corroded, all of the channels i would usually use to get OEM parts are discontinued. There's a few similar parts from different D series, but none of them are identical. Does anyone know about the compatibility between different D series?
the only one that is identical is the 88-91 CRX HF D15B6
Any of the other D-series will work - you just need to make sure it has the (2) nipples for the hoses - some only have one - if it has an oil cooler, it should have two nipples
Besides the nipples in the back the 88-00 are the same connecting pipe. Use one from a newer common D series engine.
1 - 7 of 7 Posts
