1 - 9 of 9 Posts
ok i have a P61 it came out of a b17. B17 has 3 stage v-tec ... now will it work with my Y8 or will v-tec be all messed up ill be tuneing with crome ?
my car is obd2 i will be chipping it to run moates ostrich emulator and hulog and will be tunning with crome... will the v-tec be 3 staged on my d16y8 like it is a jdm d15b or will it just be plain old v-tec ?
3 stage are you talking about the intake butterflies. So you just have a another out put you can turn on and off. If you use a p30 base it will not know any different if you us a p72 turn it off.
Even if you don’t the ecu has no way to check to see if the butterflies opened or not. Its not like when vtec fails and the pressure switch doesn’t switch. :wacko:
If you want you can use that out put for nitrous a 2nd shift light.................................. Whatever you can think off with a 5 pin relay it opens all kinds off extra opportunities. If its like the p72 it grounds when off and opens when on.
A p61 is obd1 so you will need to convert.
i know i need the conversion harness i found a guy on ebay that sells them for 30 bones so if anyone wants pm me and ill send u a link fuze im pming u...
k I love you too lol.....................
1 - 9 of 9 Posts
