1 - 20 of 23 Posts
read sig
ok so im building a little z6 only shooting for 400-450 :bigok: :) lol... well i just got a call from the machine shop and they said my p2w right now on 75mm bore is .004 wich is kinda big i think :/ but ive seen people run up to .0045 on there builds.. its a stock bore with SRP 9:1's.. do u guys think i should sell thos srp's and just pick up a set of 75.5's and b happy with it or see what happens? need advice asap thanks
read sig
.004 is perfect. Rock it.
thats wat im going to do.. ill start a build thread soon.. ive just been keeping it hush hush for a little while, trying to get all my parts together.. if i break a ring land ill blame i on u and send u the bill :bigok: haha jk
What does SRP say to run?
i dont have the SRP spec sheet but i talk to some other people and they said there spec sheet told them .0035..
i ran .0045 with my SRP's
forged slugs expand more than cast slugs like vitaras so you need to go with larger P2W clearances than usual.
read sig
read sig
thanks danz.. i should be getting the block back tomorrow :) i want her done already!
Sorry, wrong link.
1988 Honda CRX
SRP has a website. It might be JPs website.
0.0045 sounds good to me with forged pistons heavy boost.
read sig
thanks for all the replies!!!! heres a sneak peak at the motor and the car its going in (my purple people eater lol) full brake line and wire tuck :)
honda/firebird form.
looks good.. .0045 is a little loose imo... but its all in the builder and what he thinks is best... normally its .001 for every 100 hp. if this is gonna be mostly a street car, i would run a differernt clearance... if this thing is gonna see nothing but full throttle its a whole different story. you have to build the motor for what your going to be using it for.
1988 Honda CRX
SRP site says refer to included instructions.
If you where sold a set without instructions shoot the guy that sold them to you.
If you lost them yourself, shoot yourself.
I just found my SRPs and their instructions.
Here is what they say.
Measure piston 0.500" from bottom of skirt.
Measure at or close to 68 deg F as aluminium used for pistons expands more than the iron in the block or sleeves.
The clearances listed below ARE MINIMUM. Some applications such as supercharged, turbo, nitrous and endurance applications may require 0.001 to 0.003" to be added to the minimum clearance listed below.
Sports compact 2.5 to 3.625" bore 0.002 to 0.0025" basic clearance plus extra required for application.
This nets out to 0.003 to 0.0055". At 400 HP you will be closer to the top end of that. An aluminium block take a little off as does being very slightly under the middle of the bore size range. 0.004 to 0.0045 sounds the best range for your application from those instructions.
read sig
thank you sir.. i guess i need to go shoot someone!! haha jk.. well by the sounds of thos directions i should b good to go.. i hope i can make 400-450 and it will also b and a 75 shot... ill leave it at .004 and see what happens.. if she blows fuck it! ill do a sleeved block next
read sig
a 75 shot and high boost... your looking to grenade that bitch.
naaaa she will b fine.. its on a wet kit and will have a water/methenal kit.. she can handle it
Fuck it. Boost + N02 is win.
read sig
Discussion Starter #20 (Edited)
exactly!! its not like its my DD if it blows up ill b a little upset but i have a few other motors to throw in it... shes just a fun toy to play with.. i DD my EM1 and my 07 r6 :bigok:
1 - 20 of 23 Posts
