1 - 4 of 4 Posts
what would i have to do to use a p2j intake mani on a obd1 d15b head. i already blocked off where the stock egr would go but what would i do as far as sensors? n also if i used a three stage vtec solenoid with a p28 ecu itd only engage after 3000 rpm's until i got it tuned, correct? please only reply if you have an idea of what your talking about not cause you think you know what your talkin bout.
good looks bro, still need to look into it a little deeper but ill run with that for now n c whats up. all the sensors bein the same if i put my obd1 tb on that mani cause the tps n mas connectors arent the same as the obd1 tb. if ne1 else got ne input im all ears.
1 - 4 of 4 Posts
