1 - 2 of 2 Posts
Would these pistons be harmful in my D16y7?
With some fresh parts as well, valve seals, timing belt, etc etc,
Pretty much stock besides the y8 manifold, and I/H/E
Need replies ASAP! thanks
only problem i had with stock p29's is the ringlands were weak and broke. go with ones like fjt sells and it should be fine. make sure to use 91-93 octane depending on what u can get and get it tuned asap. other than this u will be fine. maybe get a cam tho cause its cool to have. lol jk but the cam will help too
when u put the y8 manifold on are u using ur y7 injectors or going with the y8s? reason i ask is cause y7 is 190cc and y8's are 240.. im not saying its necessary to switch but peace of mind is added with extra room of y8 injectors and adds further room for tuning purpose...
1 - 2 of 2 Posts
