1 - 4 of 4 Posts
So post in the "wanted to buy" section when you can.
Else hop into a junkyard, they are 10-30 bucks
The easiest way to find one, go to car-part.com and put in the info, and sort by "closest distance"
At bare minimum, all the results will show junkyards and salvageyards around you. You will find that htere are more than you realize.
PCM, ECM, engine computer, etc... are titles that might be used, then just search for compatability. The manual trans P28 is of course available in 92-95 civics and del sol SI cars
1 - 4 of 4 Posts
