1 - 3 of 3 Posts
so i bought a crx with a d16z6 in it and well turns out it needs a rebuild but w/e that not why we are here lol. its a wiring nightmare they wired the fan to a switch, the temp sensor is hooked up to the firewall plugs (and i dont get that cause it has a jumper harness so can some one try to help me figure out where do the wires from the temp switch are at the ecu (is it just a12 and the other a ground that goes where??????)
and another ? how do i hook up the fan so the car runs it...?
you hook up the fan to the switch on the tstat housing. (its on the back of the block on an a6)
the ecu reads from the dual pin plug under the dizzy
the gauge reads from the single pin plug under the dizzy
can some1 tell me what wire goes from the ecu to the switch or how it works because all i have is the tstat plug with 2 wires coming out and so i tried running it to the fan but that doesnt really seem right since u need the 12v out of somewhere so what wire from the ecu goes to the switch and how to wire the fan?
1 - 3 of 3 Posts
