1 - 4 of 4 Posts
Have check engine light on code is p1259 vtec malfunction when I press the gas pedal it doesn't rev past 5000 rpm . Do I need a new vtec solenoid ? Or could it be a wiring problem? There's enough oil because I just got a oil change . I also just got a new head gasket and got the cylinder head re surfaced .
I know im new. But you did check the oil level, right? Quick lube shops are prone to under filling. they've done it to my cars several times.
download a Honda fsm for your generation and do what it says
B-series Destroyer
4g 4d civic
What year vehicle and model?
What have you checked?
Have you inspected the screen between the variable solenoid housing and the head?
Have you checked oil level?
Have you verified that the solenoid is good?
1 - 4 of 4 Posts
