1 - 3 of 3 Posts
That ecu runs a f22a1 it is a vtec motor. It will not run your motor without some very intensive fiddling (adjusting fuel pressure changing base timing swapping a few wires on the harness) and probably still run like junk and you would have several codes like egr lift.
You can chip a p0a but you would have to hand edit everything in hex. There is no nice neat software out there for the p0a. Thy have found the checksum and some other things in the p13-p0a family.
You could not just burn a chip with crome with your motors map and run it in the p0a the layout of code is different. Crome is the p72-p05 family.
So short answer no unless you want to do some coding work. You want to sell the ecu pm me.
1 - 3 of 3 Posts
