1 - 2 of 2 Posts
M
I did a swap in my 1994 civic DX. (jdm d15b)
i bought a p08 ecu for it and need to wire in vtec because i do not have harness for it. Do i do it the same as it is done in this link?
http://www.hondaswap.com/forums/index.php?showtopic=41608
Cuz i know i am going to get CEL codes for not having it all wired in. Hope some one can help.
Thanks in advance.
run 2 wires from ECU to vtec solenoid and pressure switch, 16 gauge speaker wire works GREAT!
ECU A4 to VTEC solenoid
ECU D6 to VTEC pressure switch
ground the black wire of the pressure switch to the thermstat ground......
The hardest part will be getting the proper pins and inserting them into the ECU harness.
1 - 2 of 2 Posts
