Hi all
I'm new to Honda engines. I purchase a JDM D15B Vtec by a local Japan importer and got screwed on th ECU...
I have a P08-N51 not sure of the last digit. The 5 stands for automatiic. But the engine is Manuel.
The fucker says he doesn't have more in stock and it is not a big deal as only a check engine will apear and can be disabled if reprogrammed. I do not mind about check engine as it will be fitted on an a 1979 Austin mini without that indicator...
1- Is it true
2- Is there more difference in the mapping, fuel ratio or other things between a manual or automatic ECU then only the automatic sensor read out ?
3- Will it prevent the Vtec to activate ?
Any help would be appreciated
Regards
Honda Civic
Hi all
1- Is it true
Regards
It does not support VTEC and just convert it to manual and if you need VTEC have that feature added as well. www.xenocron.com look around.
Ok, so i need to remove a resistor and modify another one... Seams easy to me.
But the question really is: Will there be a difference between driving a modified Auto ECU converted to manual and a stock manual ecu
Any difference on fuel mapping, etc...
Let me know.
Thanks for all replys so far...
