1 - 9 of 9 Posts
Is there enough clearance with this setup:
105300 cam
2mm headgasket
1mm bigger valves
0.2mm milled head
p29 pistons
d16a6 block
the cam has much lift. I know this setup work with stock valves, but are the oversize valves an problem?
You should be fine, that cam is nothing big @ all.. Just bigger than stock :) IF you want to be on safe side just clay motor..
thanks, so I can start to build my block :grin:
yes I post the dyno next year :smile:
1 - 9 of 9 Posts
