1 - 7 of 7 Posts
ej2
Thermostat is about 2 years old.
Radiator is about 6 years old.
Just changed the radiator cap 2 weeks ago.
Just bled the system 2 weeks ago.
Not leaking from water pump, or radiator.
No milky oil, or residue in radiator/reservoir.
No white smoke. Heater blows hot.
My driveway has an incline. Backing down the incline I noticed the gauge went up. Driving uphill also cause this same effect. Idling made it go down.
However, driving down the road without the a/c on, everything is fine. That's how I made it home from school : ) :willy_nilly:
Any help?
one of a few things
-radiator is partially clogged, leading to higher temps under more engine load
-coolant is low, whether from a clogged radiator blocking access to some surface area of radiator (but still appearing full)
-water pump is giving up and not pushing as much coolant as it should be (rusting away impellers possibly)
-or a very rare one, your ignition timing is severely retarded and not advancing like it should. Generally you would notice this as have very sluggish high rpm power
get a coolant pressure tester and see if it holds pressure to weed out any leaks. then flush the radiator
Reactions: honduh666
1 - 7 of 7 Posts
