Before anyone says there's a search bar to look, I've been searching and searching different forums for days now. I recently pulled a D15B2(bad seals, almost 300kmiles, burned oil) out of my 91 crx. 98% sure it was the stock motor, the heat worked great and I never had a issue with it overheating even with a 30y/o radiator. Well I found a D15B7 that came out of a del-sol on marketplace that didn't leak, smoke nor had major issues. The guy told me he ran nitrous through it a couple of times but said it was a healthy strong motor(reputable guy in my town). I swapped over my DPFI intake manifold and dizzy and thermostat to the B7 and got a new timing kit with a gates waterpump and drop her in. Did a vinager flush to get gunk out of the motor but forgot to close the heater core. After the first 3 test drives the car would over heat and the fans not come on( most likely bad fan switch, is now jumped with paper clip). Did a few more flushes to get the gunk out and took it for a ride after bleeding the coolant system. Temp was fine until up to highway speeds, spent a day chasing it and was about to replace the HG. Decided to buy a new rad( since I'm pretty sure it still had the stock one in it ) and put it in and It didn't over heat after the first few test drives. I drive it last night to work and I get into the parking lot after crusing at 75-80mph for about 7-8 miles on the highway and I look down and noticed the temp skyrocketing, I immediately turn on the heat and it blew hot air for a couple of seconds and stuck the paper clip in the plug for the fans, after doing all that she was still in the high temps so I hit the gas in neutral to get some rpms going and she cools back down to operating temp. I drive it again tonight and I get to the parking lot and sit there(fan switch has been jumped for the entire ride). 10 mins go by as im changing a brake light and I notice the temp rising a little above half way so I hop in and hit the gas and the temp goes back down. Same thing in the drive thru after getting off the high way, about 10 mins of sitting after driving the temp goes up kinda slow but not fast either. Hit the gas and set the rpms to about 2k and the temp goes back down. I'm stumped about this and have no idea whats causing the overheating.
