1 - 16 of 16 Posts
2005 Civic Ex SE
I have an 05 civic that had an overheating issue, but i blew that motor. Just dropped another d17a2 in it march 2013. It is still having overheating issues. If i drive then it runs fine. When i stop it overheats. Fans arent turning on. If i turn on the ac the fans both run. Replaced thermostat, fan switch, coolant temp switch, relays, and did 3 flushs. Fans still will not run with ac off. Ive narrowed it down to this...if i take the thermostat out and switch it to another one, fill it up and get out all bubbles, it works. When i put the cap on, the fans turn off and on like they are supposed to. After a while (minutes-days), the fans wont work again unless ac is on. I am stumped and cannot figure out this issue. Once they stop working, if i take out the thermostat and put it back, fill it up, get out the air, it runs normal. But only for a little while. Its a continuous cycle. Idk why draining that little bit of coolant makes it work. Its very frustrating and i cant find anything online to tell me what to do. All switches and relays are working fine. Please reply with any helpful info. This is my daily driver and i want it to be fully working. Let me know if theres anything i forgot to mention. Thanks in advance.
7:06 cst...i just replaced the radiator cap and everything seems to be working fine. I'll post in a week or two if this solves the issue. Sorry for wasting ur time.
Just a stab at it, maybe the rad fan motor is taking a shit if its intermediate like that. If it does start to over heat on you at a light, crank your fan speed up to max and the heat up to max so your heatercore will take away some heat. That'll work as something temporary so you don't have to be worried about overheating everytime you stop.
I don't see how the radiator cap would effect your fan from coming on though. if anything it would either keep your coolant temp low if its defective and not allowing coolant pressure to build up OR make your coolant run hotter if its sealed too well. But either way your functioning of the fan should still work
My civic
You can always hard wire the fan switch.....
Yes without the fan the radiator gets heat soaked while your at a stand still. Radiator needs airflow to cool thimgs down. I'd wire the fan to a switch till you figure it. It would suck to lose a motor cause you got stuck in traffic for a couple hours.
2005 Civic Ex SE
sorry i took so long to reply. i am in the army and have been really busy. well i still havent been able to fix the issue. replaced the cap and that worked for a few days but the fans still wont work without the ac being on. so i have been running it either with heat on max with no re-circulation or running the ac. very frustrated since i am planning on boosting soon and this is still a big issue. i am going to replace the radiator next and see if that helps. if not once i go to turbo the water pump is getting replaced when i replace timing belt. any other ideas on what it could be? i have burped system many times and has not helped.
It sounds like air is getting in your system and possibly creating an air pocket where your sensor is and causing it to not read correctly. Is it possible your headgasket has a small leak and it is pumping air into your coolant system?
In the mean time look at the fan wires, if the fan is powered by a blue and a black wire, trace the blue wire and see if it goes into a fan relay. If it does try grounding it and turning on the key and see if the fan comes on.
2005 Civic Ex SE
Im thinking the same thing. I think the radiator isnt flowing right and causing the coolant not to touch the sensor. And theres no need for me to test the fans anymore. I have already said that the fans work.
95 ej2
I was having the same problem the fins were bent so bad on the radiator it kept blowing the fuse on the fan when it turned on. New rads arent that much its worth a shot
2005 Civic Ex SE
Thats what im gonna try. I am gonna order a rad on the 15th and see if that fixes it. If not then once i replace the water pump hopefully it stops then. I'll keep u guys posted. Thanks for your help.
Sorry if I made that sound like a fan test.... I meant to wire the grounds together so the fan turns on whenever the key is on. Not as efficient as the stock system, but a TON better than melting your engine.
95 ej2
I thought about doing that at one point also but remember its best to try and find out the original problem instead of covering it up with more.....
Its not a permanent solution. But you can do it with a paperclip in about 30 seconds if you know where the fan relay is and can access it easily. Removing it is just as fast.
And I would agree that you should find the real problem, but in the mean time you are killing your engine and expiring all your seals and gaskets. Thats not a good thing.
2005 Civic Ex SE
Discussion Starter #16
Well i just replaced the radiator today and the fans still dont work on their own. Im at a loss. The old radiator was more bent than i thought. It looked like it had been kicked in. But this one is new and still doesnt work. Idk what else to do.
1 - 16 of 16 Posts
