The answer has been given to you, so I'll streamline it for you.
Your usage of the vehicle, wether it will be a daily driver or track car determines the build. You want to have a full power band for a daily, not reaching usable power until 4-5k RPM for daily.
Your compression ratio before boost helps with this.
You will need a tuning solution, by the postings of yours I'd say Hondata and have a tuner with a Dyno to get you setup.
Use Zealautowerks.com calculator to determine the baseline compression.
Stock rod length with Vitara pistons will be very low compression, unless you shave the block and head (-.090), D16 block use a D16Y7 head, and thin (.035) metal gasket, that would be about 8.8/1 ratio with a .023 piston to deck height. Then, which crankshaft? Do you have an A6/ZC Duel oil hole crank?
Considering that the info is already in this thread, and you said stock rod length, then asked about the custom length ones, you probably should find a shop that builds engines, tell them your horsepower goal and get the price of it from them, I can tell you that parts only for this is gonna be in the $3-5k range, plus labor.
Aside from all of that, what is your brake and suspension setup? Are all of your bushings good? What transmission are you using, how about the tires?
Everyone wants the horsepower, but until you're setup to put it down in a controlled way, you're simply paying a lot of money for disappointment or killing yourself and possibly others with a 2400 pound car.
Does this help you understand better, or did I miss anything?
For context I bought my car stock, automatic. I knew I would add power so I've - Converted to a S20-B000 short ratio trans, Manual steering, full coilovers , front traction bars, Moates Demon2 added to a chipped ECU, bought all of the turbo parts for the bolt on portion, and am now getting to the engine. This is an expensive process and if you can't do it correctly, you would be better to just do a rebuild and drop it in, and enjoy your car. It also helps to have a spare vehicle.
