I have a 92 Si on a a water pump an timing belt that has seen about 8k miles. Now that its cold out (or rather staying cold out) in the mornings once the car is warmed up and I rev up under a hard accel, my temp will drop almost all the way back down to nothing. I know theres no air in the system as I have bled using the bleeder screw and I have also kept the cap open and let it run for two fan cycles an seeing no air bubbles.
I have tried replacing the thermo stat only to see the issue continue. I'm grasping for strawls and am completly clueless as to where to look next or where else to look for issues.
Any help is appreciated.
