1 - 9 of 9 Posts
Anyone experienced orange/blue spark? My friends car doesent start we have replaced the ignition coil and still wont start.. Spark is bluish with orange spark, spark plugs and wires are newly replaced.. The plug smells gasoline..
Try replacing the distributor cap and rotor, if the cap is really old it can have corrosion on the terminals inside the cap that can greatly reduce voltage output and prevent the car from starting.
Love the Civic
Did it just die one day, or was work being done?
Off top of my head, mechanical and electrical aren't firing at the same time. The blue spark is good, yellow spark is weak signal, or is the most common cause.
He said it has just died, no spark i have bck then so we replaced the ignitor and coil, now iam wondering why is the spark is color blue with orange. . cam timing and distributor placement of wires are checked.. No check engines .. Also when iam turning the dizzy with key on iam hearing the injectors ticking..my head is aching right now jahaha
whats the gap?
1 - 9 of 9 Posts
