1 - 11 of 11 Posts
d15b block
Y8 p&p head with crower stage 2 cam and crower titanium springs and retainers
vitara low comp pistons
H Beams
Acl race bearings
full fuel
skunk 2 ported intake manifold
450cc injectors
not sure on what turbo yet but something to make power
But does this sound like a starting point. Will the the bottom end setup be good with the head. Will there be any clearence issues.
whats full fuel?
What hp goal?
sounds good to me and using the vitaras I wouldn't think there would be any issues if your using the current on the market h beams or are you going to use fjt's h beams?
whats full fuel?
What hp goal?
full fuel is Just fuel pump and fpr and stuff. I was thinking eagle. Well before I decided to go with h beams I was wanting to go for 250 but since I will be putting in h beams I am thinking more in the 300 hp are. I will possibly put methonol injection on it also.
450's will do 300,but Id want room to grow and room for error so i would personally look for 550's but the 450's will do.
how much hp till I max out 550s do you think.
that sounds like a very good setup. how much boost are you going to run?
Thinking around 16-20. would that be to much on the pistons?
1 - 11 of 11 Posts
