i was on my way to work..... my hb has a lot of milage on it well when i was like 10 miles away on 275 going south to south st pete...well it started dying i had to keep pumping the gas to keep it running i ran it like that for like 8-9 miles the car was smoking a lot but it was raynning and i didnt want to stop well when i was about a mile or less from work it died a tow truck was drivin by at the same time and he stoped screeming that my car was on fire i got out of the car and looked at it it was the cat on fire he got a fire extiguisher and scuirt it 2 times and said is not going off instead of keep spraying it he left and told me to call 911 so i call 911 when i got of the phone the fire when out so now here come the fire dep. they get there check it out and say there is no oil around it so is all good and they leave i got towed to work. the car wont start and i hear a rubbing sound on the eng but it doest really sound like metal to metal. but on munday im going to start tearing in to it. i guess it could be a good thing i was planning on building an eng anyways but i was procrastinating now i got to do it? what do you guys think hapend?
maybe it was that your cat got clogged and blocked the exhaust flow and thats why it ran like shit and got on fire.. take off the cat and see how it runs... was anything else burned or on fire?
For you say anything I've done the search of done four searches and after getting to the 20th page I give up . My plan is to use a D15B7 and put the Max peating rod rods which are higher at 134.5 mm which is only at half a millimeter larger than stock rods. Along with this I plan for a z6 head...
Has anyone here actually used the Delta 260 "torque grind" or known someone who has? I'm curious about it's performance for a daily driver...
Also, has anyone used the 272 and played with the cam timing? What was the best setting for your build?
Any other info would be appreciated as well...
Hello,
I am new to this site, I have been trying to get some help from other sites for about 2 weeks now and haven't gotten a single reply yet, hopefully this site will be quicker and better suited for my needs.
I have a 97 hatchback with a rebuilt d16y7, and the acura 5spd transmission.
I...
First, I have a full d16y8 except intake is a z6. It was recently built by me i have only started it maybe 4 times to do heat cycles and to tune the idle it has not been driven.
Parts- stock head, p2p0 rods, vitara pistons, acl race bearings, arp head studs, turbo, skunk2 catback exhaust...
