1 - 20 of 24 Posts
Ok fellas I am building up Y8 for boost..... now where is the BEST place to get a new set of std compression Omnipower valves?? Thanks Pauly
civic coupe
rage racing here on the boards has them and last time i checked they are on special for d-series members :)
Discussion Starter · #11 ·
I thought they only made one type for the D-series?
no they have flat top(std comp) and then the bowl tops which are for higher compression... I think the bowls bump up the comp by .2 I just want a std comp set!! ha
88 ED6
That's the B-series. Everywhere I've looked, there was only one type of D-series valves.
isnt that backwards? the flat tops should raise compression do to the fact that u lost space in ure combustion chamber, going from a bowl to flat.
thats what i thought just making sure the paint fumes arent getting to me
1 - 20 of 24 Posts
