G
·I am looking to build a D Series at home and then get a 88-91 Crx Hf.
I'm pretty set on a D16A6 Block. I was wondering if there are any Non Vtec heads that are better than the D16A6. I happen to be good at porting and polishing and I can clean up the ports. Will any 88-00 Non Vtec head bolt on my D16a6 block? Am I better off using the D16A6 head? The cam is not an issue since I will be having one made paticularly to my specs. Also which D series intake manifold has the biggest plenum for me to make bigger?
What D series heads, blocks, Im's and throttle bodys are compatible with each other? I have my engine stand and tools al right here and I am ready to go pick up some used parts today. Let me know.
Dan
Dan
