1 - 19 of 19 Posts
Ok fellas... I am rebuilding my Y8 as some of you know. now as for gaskets, and misc stuff what all do I need? This is what I have so far: Intake Mani Gasket, timing belt, head gasket Valve Cover Gasket, Oil Pan Gasket, Water pump(with new gasket), exhaust mani gasket, new pcv valve, all the serp. belts......... anything else??
97 GSX-R 750
New valve cover bolt washers and spark plug seals are nice but not needed. I have 5 VC bolt washers from my eristic gasket kit that I don't need b/c I bought OEM's before I knew the kit came with em if you want em give me 6.00 shipped. New ones are like 2.25 a piece from the stealership.
97 GSX-R 750
Guess you're not interested in the VC washers?
97 GSX-R 750
good deal mang. I'm trying to get rid of them, they're just sitting on top of my TV LOL.
how about the oil pump 0-ring, the oil pickup tube gasket, the water tube on the back of the motor has 2 o-rings. did you get the front main seal that goes on the oil pump?
should have got a bottom end gasket set from the dealer. comes with everything from the deck of the block down. i got mine for i think 50 from the dealer.
dont forget a tube of hondabond for the oil pump and rear main seal housing and the other gaskets that need a small amount of HB on them.
1 - 19 of 19 Posts
