1 - 11 of 11 Posts
I bought an electronic Autometer Oil Temperature Gauge. Rather than tap into the oil pan, i was thinking of screwing in the sending unit right into the drain hole in the oil pan itself, however one of the supplied adapters is just a tad little too big and the other one is way even bigger (3/8" & 1/2" NPT). Anyone know where I can buy the right size adapter (a 2-way from drain hole to sender unit) or perhaps a 3-way adapter that will screw into the drain hole:
yea the threads on the oil pan drain hole are in metric. i guess i'll try to figure something out, if not, i can always drill a hole into the oil pan.
just one more question. when hooking up the Oil Gauge, there is a red wire that is supposed to be tapped into the +12 volt ignition wire. Is the ignition wire (on a 2000 Honda Civic EX) the wire with the Black/Yellow wire (IG1) or the solid Yellow wire (IG2)?
VDO makes a gauge and sender unit that fits into the oil drain plug, but it hangs down about 1.5" so pray you never hit anything.
Autometer = tap the pan, why my 2 1/16" oil temp gauge has never been installed.
Live,love,laugh,be real
96' Accord Wagon
can you drill and tap the stock oil pan bolt, there shoud be alot of meat there...
why try that, VDO has what is needed.......
Notice though how the bolt comes off the oil pan, it's protected.
Catch a rock, snow drift.....2 liter of pop.....anything and you'll rip the sender off......
1993 Civic Ex Coupe
Ok...why not just 'T' off the stock presure sending unit location?
Yes, I know, the idiot light is stock but, it has to measure the presure somewhere.
Ranger - work truck
temperature being the key word......
more accurate reading in the pool......
Ranger - work truck
Ok.
I only brought it up because I've seen it done that way on Air-Cooled VW's
yeah i agree on that, soley because they maintain temps, better than the watercooled.....too many fluctuations with the other....
1 - 11 of 11 Posts
