i found this 1/8 BSP Oil "T" Fitting fitting for a t off the back of my block so i can keep my stock oil pressure sensor and have a feed to my turbo.
it looks like alright quality, but my main concern was the thread. it is kinda hard to tell in the photo if it does actually have a tapered thread.
because it doesn't specify that it is BSPT or BSPP it just says BSP.
has anyone ran this fitting before? or tried to buy it and it turned out to be the wrong one?
i did look at the rest of the fittings they sell labeled BSP and from the photo's i could see that they are tapered.
the main reason i wanted to get this one other than a better know fitting maker is this is the only place i have found so far with that layout of the male and female.
i am also thinking of running the feed to the turbo with steel brake line so i don't have to worry about rubbing anywhere and i have all the tools to do it and some spare line.
as far as i have read around 1/4" should be fine for turbo feed line size.
any thoughts appreciated! :TU:
