1 - 12 of 12 Posts
Okay so I feel like a giant ass. I ave my car back together and I wanted to make sure my turbo was getting oil so I had a friend hold the feed line in front of a bottle.
I told him as soon as he sees oil coming out of the feed line to tell me. I fire up the car and 2 seconds later there's oil coming out of the line.
I just thought about it now and do you guys think that there is any way I could have starved my turbo by doing this? The car was literally on for 2-3 seconds before I turned it off.
I wouldn't think so,because think of it like this . When u first start the car n the moring the oil has to pump out the block and to the turbo. So as long as it wasn't running for long and u didn't rev on it it should be fine. Also y didn't you undo the drain line ?
it should be ok... but u are supposed to prime turbos before you install ur oil lines so even the first few seconds of the car running the turbo has oil.
it it should be ok...
Just unhooking the distributor clip or pull ecu fuse.
ecu fuse is all ive ever used.
op your def alright but next time the drain line will work better haha.
1 - 12 of 12 Posts
