1 - 7 of 7 Posts
Hi - so a friend and I are working on building a D16A6 engine with a turbo, and we bought the EMUSA kit online. I know ideally we should buy a better turbo, but we are working within a budget and this kit seemed to get the best comments among the cheaper options.
We don't plan on running a ton of boost, since we are working with stock internals, engine has all new seals, everything was within spec, rehoned, and the head decked professionally. Our target is around 220 - 240 hp.
One of the comments mentioned when I was looking up the turbo is that we should run an oil restrictor for the turbo, and since this seems to depend on the oil pressure that the engine generates, I was wondering if anyone knew the correct size. I haven't found any guidance on this other than it be larger than .04" in diameter.
Best,
Martin
if it is a sleeve bearing turbo, give it all teh oil pressure you can.
If it is a ball bearing turbo, compare it to a similar size garrett turbo and see if garrett recommends a restrictor on their turbo, and use similar size.
but my garret isn't a ball bearing turbo and I have to run a restrictor
Discussion Starter · #4 ·
So I found a thread in another forum that recommends a 0.064" restrictor with a -3an feed line. The kit comes with a 10an feed line and no restrictor. It is a journal bearing turbo, nevertheless everything I read about the turbo online says they work better with the restrictor. I'll keep trying to read up, but what size feed line and restrictor do you run with yours?
I don't remember, gpopshop sent me one along with the other parts for my turbo after they rebuilt it
I'm pret-ty sure that -10an is a drain and not the feed. Those kits are fairly common for skipping out on the feed. If it is in fact a feed; holy shit...
Also.. Most of these turbos are the journal bearing type that will not require a restrictor, unlike some turbos like Garrett or turbonetics, and even THOSE are few and far between. -4an feed should be fine with a universal restrictor plate of .035 or -3an with no restrictor.
Acura TL-P
If using a restrictor on a JB turbo then the common size will be .065; typically paired with a -3AN line.
-10 is the oil drain line size.
1 - 7 of 7 Posts
