1 - 3 of 3 Posts
Hello everyone,,,
Just wondering if there are other sizes of oil restrictor's for gt series ball bearing turbos. I am currently running a .035" restrictor...ive looked for a bigger restrictor but havent had any luck. Only reason i ask https://19216801.onl/ https://routerlogin.uno/https://192168ll.link/ is because i think my turbo is geting too much oil pressure and thats what casued my turbo to start smoking.
Thanks..
You’d need to measure your oil pressure after the restrictor to know what size you should be running. Ideally, you want 40-45 PSI feed pressure, and make sure your drain is sufficient. Turbosmart makes an oil pressure regulator, but it’s not cheap.
have you contacted the manufacturer of your turbo to see what they tell you?
while youre at it, ask them what size drain you should be running
1 - 3 of 3 Posts
