1 - 15 of 15 Posts
Hey Guys.
Just wondering if there are other sizes of oil restrictor's for gt series ball bearing turbos. I am currently running a .035" restrictor...ive looked for a bigger restrictor but havent had any luck. Only reason i ask is because i think my turbo is geting too much oil pressure and thats what casued my turbo to start smoking.
Thanks.
I found this on the site where i got my turbo so looks like your size is right. What is your pressure like. And are you still using the internal wastegate. I had a hell of a time trying to get my drain to point down.
-3 Oil inlet fitting for GT Ball Bearing turbos. For GT28/GT28RS/GT30/GT35R with built-in oil restrictor (0.035 hole size). Custom machined part. Output is -3 AN male flare. Use with any of our -3 oil feed line assemblies
My oil pressure seems high. Its about 80psi cold at idle...and when its warm at idle...its about 20psi. But its when im driving/cruising...it doesnt seem to matter what rpm range...the oil pressure is like 70psi. And thats when its warm cruising on the highway at like 2500-2700rpm.
So why are you looking for bigger restrictor? .035" is fine and I am running it for 3 years.
I mean I think I need a smaller restricter (smaller opening) because I think my oil pressure is tool high and that's why oil is being pushed by the turbo seals.
Not to tread jack but does this also apply to the Nissan t28 that's bb?
Ya my line and block fitting is from stealth mode performance too. I just don't know what is causing my turbo to smoke.
1 - 15 of 15 Posts
