I have a y7 block and got a new oem z6 pump, the only issue is dipstick placement...its an easy fix take your time measure measure measure and drill a hole in the z6 pump where the hole is in the y7 pump. It worked perfect and fits in the clips on the t-belt cover so it is held in place, and seals using the o-ring on the dipstick.Hope this helps.
