1 - 7 of 7 Posts
if the screws on the oil pump that secure the gear in the oil pump where to come loose would it make it loose pressure and make the car have low oil pressure. just need a yes or a no answer.
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
Yes. Lose pressure. Wait. Not the screws that hold the pump on the motor but the screws that hold the cover on the gears.
you will lose oil pressure before they come all the way out i guess. mine where so lose it took no force with a screw driver to take them out
if those screws are loose, someone has been in it. Or it is literally the worst oil pump on the market, in which case you should reveal where you got it.
1 - 7 of 7 Posts
