1 - 7 of 7 Posts
i save your ass when you wreck
94 hatchback cx
This is a dumb ? But is there any special way u have to install a oil pump?Or do u just bolt up and it's good to go
93 integra ls b18c
pretty much i have always bolted it up and went, if the block was line honed it is advised to check the clearance between the crank and pump.
dont forget the rtv
yeah make sure to put a nice thin layer of silicone sealant on the mating surfaces, replace the o-ring, and line up the gear to the crank.
then you are pretty much done!
oh and dont forget to replace the oil pickup gasket too.
94 hatchback cx
Ok did all that.. It's been honed but I didn't check the clearance but I have the pan and everything on now
93 integra ls b18c
the sleeves where honed, or the block was line bored?
2 different things
1 - 7 of 7 Posts
