1 - 4 of 4 Posts
Engine builds oil pressure as it should but if maintaining a set rpm (ie: cruising at 3k) it drops down.
What leads me to further believe it may be the pump relief valve is that on cold startup it has no/low oil pressure.
What say you? Thanks for the time ladies and gents.
same
is your pickup clean? also if the pump is out of spec then this will cause it too. might be time to replace. also port it don't shim it.
Discussion Starter · #4 ·
Well, my buddies gonna bring over his crank pulley tool and i will get inspecting. Ill post my findings gentlemen.
I have a manual, just need to grab my gauges from storage.
If i do replace the pump i will do some very light casting cleanup but not much at all.
I will be looking into the pickup as well. Thanks guys!
1 - 4 of 4 Posts
